Mac - CMD-Tab & RMB Menu = grab focus
If you use CMD-Tab to take focus away from Fusion, and you have your RMB menu open, Fusion will take back focus if you mouse over the RMB menu. It appears to be due to the creation of one of those little mouse-over micro-window menu things.
https://screencast.autodesk.com/main/details/40c9767b-b93b-4bdd-90d8-af795609866a
It happens other times as well, but this is the only way I've been able to reproduce it.
Thank you
Luke
innovatenate
Autodesk Support
Autodesk Support
I apologize for the inconvenience.
This looks like this may be a known issue based upon report ID UP-17760. It seems that this issue is being actively worked on for a not too distant update. At this time, detail I have.
Thank you for reporting this!
Nathan Chandler
Principal Specialist
