Mac cannot finish uploading saved file
Message 1 of 10
I am having an issue. I have been working on a file but it will not upload completely when I save it. It worked fine yesterday but today it just won't finish. Also the project browser is really slow and unresponsive. I have to kill my wifi (disconnect internet) just to work.
Any ideas?
J.
Replies (9)
Message 2 of 10
brianrepp
Hi @Anonymous - unfortunately this is likely related to the service outage we're currently experiencing, mentioned here.  Are you able to work offline in the meantime?
Message 3 of 10
bespenship
@Anonymous - can I work with you on this.  Please feel free to contact me at brent.espenship AT autodesk.com.
Most likely, there was a glitch in the upload process (without more information, I can't say for sure why), but you data should still be available in a local cache, even if the upload is hung.  If you can't contact me directly, can you send me your log files?  https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-manually-collect-the-log-files-for-Autodesk-Fusion-360.html (application log files)
Thanks and cheers,
Brent Espenship
Fusion 360 Quality
Macbook Pro retina - MacOS X 10.11.5 (main)
WIndows 7 Notebook
Message 4 of 10
CSGME
Observer
Observer
I'm having the same problem.
All of the sudden it's throwing up "Read access denied" and "Security Error" when I try to access my drawings while online.
Works fine while offline, however.
Problem at the server end perhaps?
Message 5 of 10
bespenship
@CSGME - this is likely related to the service outage we're currently experiencing, mentioned here.  Thank you for your patience and willingness to work offline in the meantime - we understand the problem and should have the issue resolved shortly.
Brent Espenship
Fusion 360 Quality
WIndows 7 Notebook
Message 6 of 10
keatonBQUBN
Same problem here. Any way you can give us an idea of time frame until this is fixed? This outage happened in the time between me traveling from my work computer (where things were working fine) to home.  Need access to files from my home computer before I can work offline.  Also seemed to happen right after updating but could be wrong.
Thanks.
Message 7 of 10
bespenship
We have started deploying the fix to impacted servers, so a rough estimate is within an hour.
Brent Espenship
Fusion 360 Quality
WIndows 7 Notebook
Message 8 of 10
brianrepp
Thank you all for your patience!  Fusion 360 is now working as expected.  If you continue to see any issues, please send an email to our Support team at:  support.fusion360@autodesk.com.
Message 9 of 10
CSGME
Observer
Observer
Everything back to normal.
Thanks for your hard work guys.
Message 10 of 10
Yes. Things seem to be back to normal. Thanks for your help.
J.
