Logo in Title Block
Logo in Title Block
wesley.bonafe
Message 1 of 8
Logo in Title Block
wesley.bonafe
I used to have a logo in the title block.  Can I set up a logo & a default title block with the new system?
Replies (7)
Message 2 of 8
HughesTooling
Yes, all you need to do is double click the title block and select edit title block from the dialog. You will be promoted that you need to add a title block, this will open the title block editor. From the editor you can add an image and text. You can either edit an existing drawing and add a title block or use New Drawing Template from the file menu and create a new custom template.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
wesley.bonafe
OMG this is awesome!
Message 4 of 8
wesley.bonafe
Screencast test
Message 5 of 8
wesley.bonafe
I missed something.  I did successfully edit the title block & inserted an image.  When I create a new drawing I get this:
Now when I double click the title block I get this:
I choose "Edit Title Block" I get this:
I choose "Add Title Block" I get this:
The problem is I never get th choose the title block I created.  Must I create a new title block from scratch every time or must I create a DWG file using autocad.
Message 6 of 8
HughesTooling
When I've made or imported a title block I've save it as a template you can select when creating a drawing. Not sure how it worked before if you just made a custom title block, did you need to import into every drawing or could you save it as a default?
Mark
Mark Hughes
Message 7 of 8
wesley.bonafe
I have never started a drawing that way.  Refer to screencast.  It worked!!!
Message 8 of 8
wesley.bonafe
