I am making a part which comprises of a clip and a flat mounting surface. I want the part to look nice by lofting the two together. The best way Ive found to get the shape I want is to create a 3d sketch, create a patch and loft the mounting surface to the patch. The problem is that the loft overlaps another body and causes problems where the two intersect.
Ideally I would combine these two using the combine command but in this case there are boolean errors.
My goal is to 3d print this part so if I could find a way to export it as a combined solid that would work fine.
Alternatively I could re-design the part somehow but I cant figure out how to get the shape like it is here any other way without spending hours making a ton of 3d guide rails. How would you make this part?
Any suggestions to fix this problem when combine fails? I am VERY new to 3D sketching and complex curves so any help would be greatly appreciated. Model is attached.
