Lofting and stitching help
evanDXG2P
evanDXG2P
I cannot get the surfaces in this picture to loft or stitch. The loft creates a new body but that body doesn’t seem to be doing anything. I can’t use it to machine the fillet or anything. The stitch always tells me that the lines intersect too many times and I cannot select the ones I want.
matthewrjacobs
Hard to tell from just a pic,  but if you are following Austin's video, he uses a patch to close up the bevel, not a loft.  You may be able to close that up with a loft, or multiple lofts,  but lofts like to be 4 sided,  when you introduce the pointed ends the loft can get funky.
BTW,  it's much easier to diagnose problems when the file is attached.
aliobidi
Hi ,
use "ruled " tool with "Trim " tool if not working just attach your file for take a look
TheCADWhisperer
@evanDXG2P wrote:
The loft creates a new body ...
What if you use Patch rather than Loft?
Of course the actual file in required to definitively diagnose the issue.
evanDXG2P
Hey guys - here is my file if someone wants to explain what I need to do. Sorry I meant to attach it before but was on my phone.
aliobidi
you have 2 options
first with loft
second with ruled
see this screencast
your file below
matthewrjacobs
Or Patch
