Announcements
Lofting Airfoils
Lofting Airfoils
I am trying to loft airfoils with a twist. The twist is between 5 and 20 degrees depending on the particular wing. Airfoils with thin trailing edges wont loft at all saying that the shape intersects itself. Should a construction axis work as a rail? I can't seem to make it work. If I find shapes with fat trailing edges I can make the loft but the leading and trailing edges taper in the middle.
Replies (7)
wmhazzard
You can grab the offending rail and pull it out to the tip of sketch 2.
TrippyLighting
The loft profile has pretty bad curvature toward or right at the training edge. that will certainly be one problem.
Yes, I have tried:
1. Generate airfoil and place a circle at the aerodynamic center.
2. Create an off set plane 30” away
3. Copy the sketch to the new plane
4. Rotate the new sketch 15 deg about the aerodynamic center.
5. Create two axis, one from the trailing edge points and in from the leading edge points.
6. Using these axis create two planes at an angle.
7. Project the points used to create the axis.
8. Snap a line in each sketch.
9. Loft using these lines as rails to keep the leading and trailing edges straight.
For thin airfoils and/or large rotations I get the rail does not intersect profile error.
wmhazzard
Is this not what you wanted?
There are two versions. One with all three sketches rotated and one like your original.
wersy
As @TrippyLighting  already said, the problem is the trailing edge.
The problem occurs with all splines whose dat file begins at the zero point. Here the pointed end is deformed.
This also causes problems for Inventor.
Either I rewrite the dat file or I edit the spline.
I don't want to have deformed ends anyway.
In this case I just separated  the end:
This is the result:
Michael
Thank you! I was able to get it working with your guys' help. Now to get the shapes just right.
wersy
Not only is the wingtip deformed.
Even worse is the leading edge of the wing:
This is because the spline ends are not tangentially connected.
I used the points to draw a new spline, but started from the end at right.
That looks much better now:
If there is a solution for you, you can mark one or more solutions so that other users can benefit from it.
Michael
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
