Lofting a pipe
Lofting a pipe
karl
Lofting a pipe
karl
I'd like to loft between two pairs of concentric circles to make a pipe whose wall thickness is the difference in radii of each pair.  The loft tutorials I've seen all produce solids or surfaces, nothing hollow with a wall of finite thickness.  Is there a way to do this?  I've tried in my own design but always get a solid.  I'd include a screencap, but my drawing is sufficiently complex I've found it hard to display what I'm trying to do.  I'll try to divide it up into more sketches so I can turn visibility off for some things, if necessary, but thought I'd check here first to see if there's a simple solution.  Thanks.
Warmingup1953
Loft uses Solid profiles but you can do an outer solid loft and then an inner solid loft then use combine cut. Your post had no attachment.
TheCADWhisperer
Shell.
