Lofting a corner
Lofting a corner
Message 1 of 29
Lofting a corner
Does anyone have any idea on how to loft this corner?
It seems simple and straight forward. What am I doing wrong here?
I have used similar functions in other software without issue, Any idea on how to loft this correctly?
Or a different process to achieve a nice capped corner?
Cheers
Screen Shot 2017-07-14 at 12.55.00.pngScreen Shot 2017-07-14 at 12.57.02.pngScreen Shot 2017-07-14 at 12.57.20.png
Replies (28)
Message 2 of 29
HughesTooling
You need a single rail curve, can you chain select where you have 3 rails. And as I asked in your other post, can you export your f3d file and attach?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 29
cekuhnen
@HughesTooling@Anonymous
I would loft to a point by using the sides as rails
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 4 of 29
SaeedHamza
Please try this method with a sweep, worked for me so I hope it will work for you as well
Regards
Saeed
Saeed Hamza
Message 5 of 29
SaeedHamza
Forgot the screencast ...
Saeed Hamza
Message 6 of 29
cekuhnen
@SaeedHamza
In this case Sweep visually looks fine but only because we deal with an arc fillet and tangent planes!
With G2 fillets this fails - just be aware of it
Claas Kuhnen
Message 7 of 29
SaeedHamza
Yes, it's not functional, I just thought it might work for this issue, although loft should solve this
Saeed Hamza
Message 8 of 29
cekuhnen
@SaeedHamza @Anonymous @HughesTooling
Actually not at the moment. Loft lacks the tools for it when dealing with G2 or non circular geometry.
Mainly the G1 G2 option for rails are missing - but should be added soon.
https://drive.google.com/file/d/0Byzv_NlyKp_2Nm9lSVBkeWR0Qkk/view
Claas Kuhnen
Message 9 of 29
SaeedHamza
It's tricky even to notice it when using loft
Although it works
Saeed Hamza
Message 10 of 29
HughesTooling
All poking in the dark without the OPs model. All his edges are made from 3 curves, assuming it's 2 lines and an arc there could be problems if the lines are not tangent to the arc.
Mark
Edit One edge has 4 curves, I think that puts a sharp corner in there unless the 2 top faces are coplanar. Not sure how loft will deal with that.
Mark Hughes
Message 11 of 29
SaeedHamza
by the way, extruding then lofting seems to work just fine, don't you think?
Saeed Hamza
Message 12 of 29
SaeedHamza
Yes, having the model always reduces the effort of finding the answer, but most of the people posting in forums make us ask for it
Saeed Hamza
Message 13 of 29
Thank you everyone for your replies. As SaeedHamza has said a sweep would be nice but with this complex model it doesn't work. Loft seems to be my only option but I cannot get it to work.
cekuhnen you mentioned lofting to a point and using the sides as rails, I have no idea how to do that?
I have attached the model as everyone has requested it.
Cheers
Message 14 of 29
cekuhnen
@Anonymous
how did you build that solid model
this one is going to be a pain to fix/repair.
Claas Kuhnen
Message 15 of 29
Its an imported model from a client... My thoughts exactly
Message 16 of 29
cekuhnen
can be that through exports the original data got lost or changed but this is a total mess
rebuilding will be faster - however to be honest I think Fusion currently is not able to do this sufficiently.
their tools are more focused on easy simple geometry and not something like this which has uneven sides
regarding loft to a point:
https://drive.google.com/file/d/0Byzv_NlyKp_2MGxSZ0tIV1NLZGc/view
Claas Kuhnen
Message 17 of 29
Woah how did you get that view? of all of the disjointed surfaces?
Thanks for the tips on point loft
Message 18 of 29
SaeedHamza
You're beyond helping my friend, this model is really messed up ...
Nothing accurate to use ... I think that the patch is the best thing to do with all this, other than that forget it
I recommend you as @cekuhnen said above to rebuild the model, it will be a lot faster for you and your client
Saeed Hamza
Message 19 of 29
laughingcreek
this one is challenging.  This is my quick stab.  couldn't get both sides of loft to have a tangency connection because they come together at a point at the top.  always a self intersection problem in that situation.  There are approaches to fix that. As the others mentioned, the input geometry is already a mess, so this may be good enough?
Message 20 of 29
cekuhnen
@Anonymous
I exported the design as STEP to open it in MOI which is a cheap Rhino clone and a basic NURBS modeler (pretty easy to use and quite powerful).
The colored edges are the raw surfaces. I untrimmed all the details to see how the design was constructed to see if there is something I can do with
it but the parts are such a mess ...
Also I took another try on the model and cannot build it with a surface perfection I expect. The geometry is pretty crazy.
So my question is how far can you rebuild and clean it up for your client? Fusion 100% lacks the ability to do what you want.
However the data the client gave you is also plan crazy
There are plenty of inaccuracies - lazy edges, edges that have sharp and not smooth transitions and such.
If you can adjust those then this model can be rebuild much easier in Fusion.
Claas Kuhnen
