Hi- Really hoping someone can help me because I am at a loss. I am completely new to Fusion 360, so this absolutely may be user error. I am trying to create a cookie cutter (I've created about 10 of them using this current process with minimal issues). I create a sketch, offset it twice for my walls, extrude said walls to the. height I want, then I create a plane above that at the height that I want my cutter blade to be. I project my sketch onto that plane and offset that sketch by the width I want my cutter blade to be. I then extrude the inner body to fill the space, and from there I use the loft function to connect the surface of the cutter to the offset space of my projected image on the plan above to create a tapered edge. To finish, I use the extrude function to cut out the middle to create the cutter shape. For this particular shape, for whatever reason, when I use the extrude function to cut the middle out, it's taking part of the lofted wall with it, but only in one particular spot. I have tried changing my original sketch, I've tried starting over, but each time, I end up with a jagged edge right in that same spot. I'm not sure what I'm doing wrong? I've included images of the my original sketch, the loft, and then the cutter after using the extrude function to cut out the middle. The other cutters I have created this way have all been complex shapes with rounded edges similar to this one, but this is the only shape in which I'm running into this issue, and only on the one side, which I find strange. Thanks in advance for any help!
