Loft in a circle
Loft in a circle
atash.hauschild
Loft in a circle
atash.hauschild
I'm trying to do a shape like in the phot by lofting the bottom and side surface together. However I only get those straight lofts, not following the shape of the circle. What can I do?
IMG_0086.jpgScreenshot 2024-08-10 at 20.35.25.pngScreenshot 2024-08-10 at 20.35.14.png
jhackney1972
Please Attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
JamieGilchrist
Hi @atash.hauschild  Don't use loft, there's a much easier method.split face with a conic curvesplit face with a conic curve
Press/Pull offset face from the split face body
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
atash.hauschild
Wow that's awesome! Took a bit to understand haha but works like a charm. Thank you so much!
