Loft Design Help
Loft Design Help
joeralat
Message 1 of 11
Loft Design Help
joeralat
Hello, I wanted some advice into a lofting issue I am having. I am having some issues making one loft "body" I have to make two lofts and stitch them together. The issue is that I am getting a seam because of the stitching. I wanted to make one loft but I am not able to use one of the rails. I keep getting an error when I use one of the rails. Any help or advice would be greatly appreciated.
Some Step by Step of what I did
I created a Sketch (Called MainBody+Rail)  I am using two points on this sketch to make a loft. I am also using this sketch as one of the rails.
I then made another sketch with a line to use as a profile. (Called LoftLine)
I then made another sketch with a line to use as a rail. (Called Rail2)
I went into Patch mode and created a loft. I selected the point at the tip of the sketch (Called MainBody+Rail) then added a profile from the sketch called (LoftLine) I then again added a profile(Point) from the sketch called (MainBody+Rail)
I then added a rail using the Sketch (Called MainBody+Rail) and the surface that was created when lofting conformed to the rail, but when I try to add another rail using the sketch called (Rail2) I would get an error.
In the file is the resulting body. made with two loft bodies stitched together. I then extruded the sketch called (MainBody+Rail) (I am back in model mode) I went to modify and while the new extrusion was selected, clicked replace face. I then select the new body created from lofting and replaced the face. Again the final body result is called (FinalBodyResultSeam)
 If someone has a better way or advise to make the final body called (FinalBodyResultSeam) I would appreciate that too.
Again thank you and any help would be greatly appreciated.
Also if anyone knows of tutorials free or paid that goes into depth about lofting.. I would appreciate that too. Again Thanks
Replies (10)
Message 2 of 11
TrippyLighting
Is this the geometry you are trying to create ?
Message 3 of 11
joeralat
Hello, thank you so much for helping... Not the shape I am trying to get..In the file in the new component called WingSection and in Body. You should see a body called FinalBodyResultseam..that's the body I want to make, but without the seam on the top face. I want one smooth face from front to back. If you render that body, you can see the seam in the render.
Again thank you so much and I appreciate the help.
Message 4 of 11
TrippyLighting
That is geometrically not possible. Not a Fusion 360 problem but with your understanding of geometry.
The rails as you've defined them are not curvature continuous ( not G1 or G2). That cannot create a curvature continuous surface.
Message 5 of 11
joeralat
What would be the best way to make that exact body shape without the seam on the top face? Thank you again
Message 6 of 11
davebYYPCU
Do the Loft in one piece to remove a two piece seam result.  Edit my feature, same geometry, different selections
Might help...
Message 7 of 11
TrippyLighting
As Iv'e stated already, you cannot make that exact shape without that seam. That is geometrically impossible.
Message 8 of 11
joeralat
Message 9 of 11
TrippyLighting
Can either of you two explain to me how that differs from the object I created in the screenshot above ?
@joeralat I asked you whether that is the geometry you were looking for. You said "NO".
@davebYYPCU goes ahead and creates exactly what I created and its what you are looking for, but is NOT exactly what you've created in that body in your original file.
#mindblown
Message 10 of 11
joeralat
Trippy can you please post your file..Thanks
Message 11 of 11
TrippyLighting
Sure!
