Loft command help
Loft command help
zdenek.hajn
Message 1 of 8
Loft command help
zdenek.hajn
Hi, i have 3 airfoils in 3 planes. I would like to loft them together, but I get errors... Can I make it this way, or I need to make it without loft. Yellow field looks like I would like to have new body...
Thanks for helping.
Replies (7)
Message 2 of 8
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
Message 3 of 8
zdenek.hajn
Source file, sorry.
Message 4 of 8
davebYYPCU
I can check your file at a later time.
The yellow body, is preview, and it is announcing that the volume is in some way effected by a self intersection.
you may find that you need exactly the same number of spline points in each profile.
You may find you need a number of Rails.
If the airfoil profiles are exactly the same, then you can change to Sweep command.  Sweep with Path and Guide rail/surface.
Might help....
Message 5 of 8
TrippyLighting
If you use a surface loft instead of a solid loft, it works fine.
@jeff_strater maybe there's some room to improve the solid loft behavior.
Message 6 of 8
zdenek.hajn
I get the same result with surface loft... Yellow lines and errors...
Message 7 of 8
TrippyLighting
I see. The behavior of the lot tool could definitely use a bit of help here.
By pure coincidence I got it right on my first try, by selecting the curves, not the sketch profiles created by those curves.
Message 8 of 8
zdenek.hajn
It works... 🙂 Many thanks
