Loft and object with curved faces
I've created this cylinder with an additional shape inside shape the negative space. I created the form inside by lofting a sketch on the top face to one on the bottom face.
This might have been the wrong way to do this, but I'm now getting some space on the sides (the inside shape doesn't touch the cylinder walls). Is there a way to fill in this space, or correctly re-create this interior shape?
Hi.
Can you select those faces ad try hitting delete on the keyboard. Fusion will try heal back to another surface. Not sure if it will work in this case but its worth a shot.
Thanks, regards,
Daragh
I_Forge_KC
I would loft your two sections from the OD instead of the ID.
K. Cornett
Generative Design Consultant / Trainer
