loft a hull
loft a hull
Message 1 of 20
loft a hull
Hi, I'm trying to loft a hull design with both fore and aft with sharp edges. I'm using loft command in patch environment but it don't work. What do I do wrong? /Martin
Replies (19)
Message 2 of 20
How do I insert a public URL?
Message 3 of 20
TheCADWhisperer
Message 4 of 20
cekuhnen
@Anonymous
screen shot would be useful 😉
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 5 of 20
Thanks. Here is the file.
Message 6 of 20
Hi again. Thanks for instruction how to attach a file. Here you have the file where I'm trying to loft the hull around the spline lines. If I use a flat aft i can loft but it seems like when I want sharp edge of the aft I don't get it to work. How come?
BR Martin
Message 7 of 20
cekuhnen
@Anonymous
Loft in Fusion is unlike loft in surface modelers it somewhat can do many things at once - meaning they implemented function from
multiple tools into one.
So regarding your boat you cannot loft it because loft needs either
1. profiles that are apart from each other to skin a surface through them like a band
2. profiles where the ends touch each other so we we can make surface like a sphere or umbrella
Here is a quick screen cast to show you what does not and what set of profiles work
https://drive.google.com/file/d/0Byzv_NlyKp_2RmVkMlg5YkpFY1U/view
traditionally for boat design you can also use vertical profiles and loft rail them
https://drive.google.com/file/d/0Byzv_NlyKp_2c1hXejZNTnZQVjg/view
Claas Kuhnen
Message 8 of 20
at around 3:30 he starts going into lofting. This tutorial helped me learn loft.
Martin
https://www.youtube.com/watch?v=sRC4t3OyxkU&t=475s&index=15&list=PL0hnohblr3hvBVkxejtBrvbA1OB2cnO8H
Message 9 of 20
Are you trying to do something like this?
Message 10 of 20
WHolzwarth
Hmm. I wanted to try it with Inventor.
Smiley Frustrated But none of F360 export capabilities seems to be able for export of sketch geometry.
Is it fact, or am I missing something?
Walter Holzwarth
Message 11 of 20
That's funny.  This is a technique I developed in Inventor and this is my first Fusion part.
I can post an ipt.  What version of Inventor?
Message 12 of 20
WHolzwarth
Your file is an easy task, Richard.
Type3 v2.f3d is the challenge
Walter Holzwarth
Message 13 of 20
My bad.
I should have paid attention to who's message you were replying.
Message 14 of 20
WHolzwarth
No big deal, Richard.
Smiley Wink Kudo for your excuse.
Walter Holzwarth
Message 15 of 20
LOL
Actually, what I was trying to achieve by posting my file was to discern the design intent from the original poster.  Do the rails he shows represent the keel, chine and sheer of a hard chine hull?  If so, perhaps my approach could work.
Message 16 of 20
Hi rhinterhoeller. No, this is not what i´m struggling with. The challenge is to loft a hull with sharp ends in both front and aft of the boat.
Message 17 of 20
Hi, It does represent the keel, chine and sheer of a hard chine hull but the difference to your hull is the shape in aft.
Message 18 of 20
SaeedHamza
Hi Martin,
Could you please attach at least one screenshot of what you want to do for more understanding
Regards, Saeed
Saeed Hamza
Message 19 of 20
Thanks Claas! This works fine=) I must have missed to add a new profile by press + sign...
Message 20 of 20
cekuhnen
@Anonymous
no worries - you did not miss anything.
currently the loft code sometimes has still issues with selecting profiles as new edges and not joining them.
i had the same problem till I figured out why loft did not want to work
Claas Kuhnen
