Locating Sketch Unconstraints
jeph00
jeph00
Hello everyone.
As I understand it, when there is a lock next to the sketch symbol and all the sketch lines are black it means that the drawing is fully constrained, like in the screenshot attached.
In the part I have attached, it shows that it is not fully constrained, even though all my lines are black. What are ways I can determine why my sketch is unconstrained?
davebYYPCU
Yes all black lines is a requirement along with no white points.  You have one of these.
You are victim of the coincident points are hidden trap.
I see no benefit in this model of projecting a plane, even though it has no bearing on the problem.
If you are the author of the sketch, you should be able to find it,
Might help....
etfrench
Enter this in the Text Command Window:
  • Sketch.ShowUnderconstrained
File -> View -> Show Text Commands
ETFrench
TheCADWhisperer
...did you find it?
Two lines ending here where there should be only one construction line.
g-andresen
follow @etfrench
günther
jeph00
Yes @TheCADWhisperer I got it. Used the Text Command like @etfrench suggested. I did not even know that was possible. Thank you all for your help @g-andresen @davebYYPCU 🙂
