Linked Component with Sub Components Align Behavior
srgntballistic
Message 1 of 8
srgntballistic
I have a linked component I've imported into a design. If I use "Move" on the component all of the sub components move together.
However, if I use "Align" and pick a face on one of the internal bodies/components it only moves that body/component. The rest stay where they are.
In this case it's an Adafruit Neopixel Jewel board with a lot of subcomponents representing components on the board for clearance/alignment purposes.
I'm trying to align the bottom surface of the PCB with a surface in which I'll be mounting it.
I was under the impression that with a locked component you couldn't edit or move any of the subcomponents. You have to edit the original component. Is this the expected behavior?
Replies (7)
Message 2 of 8
lichtzeichenanlage
Your sub-components are not joint. Because of the the align command fails. Join the components and it should work.
BTW: you should prefer joins over move/aligns.
Message 3 of 8
srgntballistic
Joints don't seem to work well for what I'm doing. I'm designing for 3D Printing and as such have to build in some registration and tolerances.
So when I try to do a join on two registered pieces with say a .4mm offset on all sides of something like a cylindrical registration piece the the join will often overlap the 2 pieces. I've tried doing planer first then adding another and it doesn't seem to work
Message 4 of 8
lichtzeichenanlage
Not sure what you mean. Can you share the design and / or create a screencast?
Message 5 of 8
michael_koehle
It would work better if it aligned the component. If we wanted to align subcomponents, we would active the subcomponent.
Message 6 of 8
lichtzeichenanlage
Could you post an example or better what you're struggling with?
Message 7 of 8
Repro:
1. create one component with one body, a simple flat box
2. create another component with one body (B) and one subcomponent (C)
sub-componentsub-component
3. import (2) into (1)
4. move the imported component (3)
align-beforealign-before
5. select Align
6. click the face of the BODY (2B) from the imported component
7. click the face of BODY (1)
align-actualalign-actual
EXPECTED (in step)
7. entire imported component moves, since the COMPONENT (2C) is a child component and the BODY (2B) is a child of the component.
align-expectedalign-expected
ACTUAL (in step)
6. only the BODY (2B) moves, while the subcomponent (2C) stays in position
ADDITIONAL NOTES
* Making additional hierarchy of only components in sub-component also does not work. For example, make sub-component have no root-level bodes, just two components (C1 and C2). Make C2 a child of C1. When aligning (7) you've selected the parent component (C1). Reasonable assumption is that all children of that component will also move, otherwise why is their a hierarchy?
EDIT - And, moving the imported component, or the root of the imported subcomponent (C1) will also move C2, the child. It is only the align command that fails to move C2.
EDIT - Potential workaround - in some scenarios, using the Move tool with Point-to-Point instead of Align may work. Also, this moves the entire hierarchy as well! Select Move, select point-to-point, click the bottom corner of C1 and then the top corner of the parent box. The whole hierarchy moves!
Message 8 of 8
lichtzeichenanlage
Don't use move and / or align but joins.
