lines projected from a solid body don't always behave as continuous path
Quite often, when projecting a solid body into a sketch, find that lines which were projected from a continuous surface don't exactly behave like they are all connected.
Have noticed this in two ways:
1) If one tries to make a surface to extrude using various projected lines, well that's not possible. As a work around start drawing lines to divide what should be a surface into areas to find out where the hole(s) is. Fix the hole in the projected lines by adding lines manually of my own.
2) If wishing to sweep a profile along the projected lines, find that cannot select all of the lines because there is some kind of discontinuity.
Anyone else noticed such things? Are there any tricks?
