Linear Pattern Problem
Unable to solve the linear pattern problem.
Any help appreciated in explaining how to do so.
dlw
https://a360.co/2KwR4Ar
tommVS2MB
Please, tell me more. I am not sure where the problem is
Tom Meyers
Thanks for replying.
The drawing did not post as expected. My fault.
The sander is 2 parts. Front for sanding, back for support of front and drive motor.
The front is attached through the back.
On the rear of the front is where the sanding plane and its supports have screws to make one assembly.
The problem is the linear pattern did not work properly due to not me knowing enough.
There is one hole drilled at the bottom and needs to 2 more above it and these three copied to the other side.
I tried and tried. Watched  tutorials. Simply do not understand the error message in the time line regarding the problem.
dlw
