line section delete
line section delete
line section delete
Hi everybody. how can i delete a portion from a continuous line or spline ,between 2 points,upper or down one, like in this image?  thank you
HughesTooling
I think your only option is to draw lines across the spline and use Trim or Break.
Mark
Mark Hughes
Owner, Hughes Tooling
hi. thanks for reply. but no ,because a draw it the lines and closed at the end and after revolved them. but now i want to modify the lines to cross 2 lines ,1 from the botom with 1 from top of the picture and not to delete them and start drawing from 0. if exist a solution.
jeff_strater
Hi @Anonymous,
I apologize, but I'm not sure I understand what you are trying to do with this sketch.  Where do you want to trim the curves?  Why does @HughesTooling's suggestion of using Trim not work for you?
You may have to share your design to get more help...
Jeff
Jeff Strater
Engineering Director
