Life after nesting: Designers without CNC machines would ❤ a native multi layered dxf export.
tookemtoni
Message 1 of 1
tookemtoni
Hey, Are you a designer without a CNC machine but want to get your designs manufactured?
I made a comprehensive description for nesting (aka arrange) and the current state of dxf exporting in Fusion 360 over the manufacturer forum: https://forums.autodesk.com/t5/fusion-360-manufacture/designers-without-cnc-machines-would-a-native-...
The post is focused on users who...
  • Need a dxf export option which can translate 3d part perimeter, inset perimeter or diameter with depths, v-cutting and engraving into dxf layers.
  • Are working with designs that can be manufactured with 2.5 axis milling
  • Are working with large designs +100 parts
  • Are working with sheet materials such as plywood, MDF, laminates etc.
  • Need nesting to control material usage
  • Are working in woodworking, furniture or cabinets for example
I would love to hear your comments and other workflow ideas.
Replies (0)
