Leader Notes not functioning in Drawings
HarrisonClassic
HarrisonClassic
Since
Fusion 2.0.19994 x86_64 I can no longer add properties (general, physical or a parameter) - all I get is "dashes"
@JamesMannFusion
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
jhackney1972
To state the obvious cause, the property you are trying to use is empty.  I to get dashes is the property has no assigned value.  Also, if you add a property value in the model, be sure to save the model to get it to propagate to the drawing.
John Hackney, Retired
HarrisonClassic
Won’t even place in the component name…
David Harrison
johnsonshiue
Hi! This could be a corrupted font issue (AMGDT or AIGDT). Please uninstall and reinstall the fonts.
Many thanks!
Software Test Engineer
JamesMannFusion
Hi Dave,
Did you get this sorted using the above or are you still stuck?
