Latest update... Moving components between assembly groups is broken
In the past, you were able to select a component or multi-select a few components and move them into an assembly group.  This functionality is either broken or no longer supported.  Does anyone know which?
jeff_strater
Neither, actually.  This functionality has not changed recently.  However, whether you can do this or not will depend on the relationships that exist between your components and other components in the design.  If you have references to sketches in other components, for instance, this restructure can be blocked.  It is very design-dependent.
Here is a simple screencast showing it working on a very simple design:
Jeff
Jeff Strater
Engineering Director
TrippyLighting
Make sure you timeline is rolled all the way to the end.
