Keyway Dimensions on Drawings (Tangent Dimensions on Drawings)
Hello All,
I'm trying to create a drawing for a gear which happens to have a keyway slot (Check the image). How can I dimension this keyway similar to attached photo which is pretty much standard practice?
Thank you!
Keshava_Murthy
I assume you are trying "Dimension (D)" command to a dimension the key-way slot.
Please try "Linear Dimension" from the Dimensions Panel drop-down.
Please click ACCEPT SOLUTION if my post helps in solving your issue or answering your question.
Keshava Murthy
AutoCAD Mechanical Team
Thank you for your answer. This works for technical drawings.
Unfortunately for sketches it doesn't work since there is only 1 dimension command.
