Just Starting need help
drawitdan
drawitdan
All new to CAD. When viewing tutorials my drawing seems not to be the same plane. They ask to pick a plane and my datum is reversed to that in the tutorials. So when I draw to the right the tutorial is drawing to the left. When i write text its as if I wrote on a piece of glass and then turned it left to right 180 degrees. Text is backwards and reversed. SEE ATTACHMENT FOR PIC
Also how do I delete projects and drawings I saved. I would like to manage my files in fusion.
Any help would be deeply appreciated
Dan
It looks like your default model orientation is set to Z up, while the tutorial should be using Y up. You may try changing that in Preference to see if it works.
ADSKDJW4
Hello drawitdan,
Here is where you can access the preferences and the setting. If you correct this does it help?
then
Resetting this does it correct your issue?
Don
Autodesk Fusion Support
