Hi, I'm trying to draw a series of baffles inside a pipe, and am stuck trying to add the steel angle I want to use as shelf supports.
I'm trying to put a series of steel angle pieces inside a pipe at intervals along the pipe to make supports for baffles at 15cm intervals. I can draw the angle, I can draw the pipe, but I can't come up with a way to join them - there aren't any features inside the pipe, and no geometry to tie it to. I can't see how to add the brackets as components that are joined to the pipe.
Just to make it harder for me, the baffles are about 3/4 of a circle with the opening alternating from side to side as you go up the pipe, so I need the support brackets at an alternating pattern. At 300, 600, 900, etc along the pipe I need brackets at 0, 120 and 240 degrees around the pipe, and at 150, 450, 750, etc along the pipe I need the brackets at 60, 180 & 300 degrees around the pipe. I can do it with a simple piece of bar on edge, because that's just a pattern drawn around the circumference of the pipe end, then repeated up the sides.
Pic added to show the basic idea of the join I need.
