Joint Selection Issues
dolanjamesp
Observer Observer
dolanjamesp
Observer
Observer
The screencast linked below shows the issue I am having
http://autode.sk/1R1r1hc
Essentially, I am unable to select any features that are recessed on the second part for joints. It seems that there are planes blocking access to these areas. I tried making planes and sketches invisible, but I still cannot select the features I need to. Is there something I am doing wrong or is there a solution for this problem? Thanks
TrippyLighting
Yes, you should not really use a panar, but a revolute joint.
