Joint preview places component but then doesn't position it after clicking OK
jcwren
Message 1 of 1
jcwren
I've created any number of joints successfully, but then this odd behavior started. I select component 1 and then component 2, it positions the wireframe version as if it's going to do it, then clicking OK results in a joint in the Joints folder (in this case `Rigid 44`), but component 1 isn't moved to the joined position.
Component 1 is the Top Level->Accessory Hardware->8-32 Screw + Washer assembly and component 2 is the Top Level->Cabinet Side Block Off Plate.  As far as I'm aware I'm not doing anything different from the other components I've similarly done. There's no warning or error messages being thrown. What am I missing here?
Replies (0)
