Joint origin not built in component
jlucasemail
jlucasemail
Both joint origins were built with the component active but only one was built in the component, the other in the project.  See  https://a360.co/3OV3H87
jeff_strater
Joint Origins are one example where the owner of the object is not determined by the active component.  Instead, it is determined by the component that owns the geometry picked when creating the Joint Origin.  In this case, the upper Joint Origin looks like it was created by selecting geometry from Sketch 1 owned by the root component (Tester), so the Joint Origin is then owned by the root component as well.
Jeff Strater
Engineering Director
jlucasemail
Ah!  That makes sense.
All I need to do is hide the sketch then all joints are owned by the component.  Thanks for the prompt response.
