I may have bit off more than I should have, since I'm just learning Fusion 360, but I was excited to just jump right in.
I wanted to try and emulate a mechanical movement across 8 sections and several connection points. I tried it first with 4 sections and had somewhat success, but when I tried to expand to 8, I ran into different conflicts with the joints. I've attached the current file version for reference.
Once I tried to complete the 8 sections with joint assignments, I saw that the previous joints turned red and errors were pointed out. I tried to figure out the errors and tried to adjust the directions and trying the flip button. No solutions.
Now I have further impacted the previous joints and they will not connect to the model anymore.
Baffled!
I appreciate any direction/advice.
Martin
