Joint between rigid groups
javelin_exile
Message 1 of 14
javelin_exile
Hi Folks
I have a new model I'm making that I've imported 2 models into as components and made each into rigid groups so they hold together. Now I'm making a revolute joint between these 2 rigid groups so that they can function. The 2 groups are already positioned but as-built joints don't work. There is no error or anything the dialog just doesn't come up. I can use a regular joint to join them and it does work but one of the  2 components tilts 5° as soon as I click ok. the joint stays at 0° the part moves and is 5° turned from where it was. how do I track down what's happening?
Replies (13)
Message 2 of 14
jhackney1972
The only way I know is to attach your model to a reply post.  I tried what you described and it works OK for me.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Message 3 of 14
javelin_exile
HI
I can't attach this particular file but it's happened again on another assembly. Here's a video of trying to add the joint and the results. As soon as the joints are made the part turns. it's only happened since I made these rigid groups.
Message 4 of 14
TrippyLighting
@javelin_exile wrote:
... how do I track down what's happening?
Inspect the orientation of the origins of your components!
I bet one of them is rotated 5 degrees.
Message 5 of 14
johnptc314159
around the 9 second mark the joint axis x and y seem to not line up with the vertical ( they are rotated).  i think once jointed fusion  rotates it to line up with the other part.
Message 6 of 14
javelin_exile
Found a tweaked origin and aligned it with the others but it still twists when the joint is added. it's the weirdest problem.
Message 7 of 14
javelin_exile
yea that's what's happening, I found a twisted origin and fixed it with align but it still twisted after the joint. see the new vid I posted I tried to align on the origin plans again and the twisted one pulled the ones from the other parts but not all of them.
Message 8 of 14
johnptc314159
might just redraw the bearing assembly 🙂
Message 9 of 14
davebYYPCU
What about you find the actual problem, and then edit the original assembly.
Might help....
Message 10 of 14
javelin_exile
Perfect, why didn't I think of that lol
Message 11 of 14
javelin_exile
I worked around it but saved the files as they werre. these purchased/imported parts sometimes cause issues here and especially in Solidworks and I'd really like to know how to find and where to look for these issues.
Message 12 of 14
davebYYPCU
Usually becomes self evident when you unhide the Origin Items.
Might help...
Message 13 of 14
javelin_exile
Is there a global command to unhide these items? I can turn them on and off in display settings but it won't change the state of items that are buried in components.
Message 14 of 14
davebYYPCU
Global setting switched on, and
Browser eyeballs show and hide them as required.
For every new sketch the origin planes are displayed at time of creation, regardless of the Eyeball status.
Might help.....
