Message 1 of 8
Joint Animation Freezes When Using Tangent Relationships On A Fit Point Spline
Hello, I am having trouble getting these joints to animate properly, If I rotate the cam without the "pin slot" joint it will animate all the way around the cam. However as soon as they are both active it will freeze or skip over the section of the cam that is the a spline point. The goal is to have the last link(Blade Profile) to stay fixed at 10 degrees. I have tried motion links, contact sets instead of tangent relationships and all seem to run up against the same issue where it stalls or skips part of the cam. Perhaps I am trying to achieve it the wrong way? Any thoughts or suggestions would be much appreciated. Thanks
