January 19, 2017 Update - What's New
keqingsong
Community Manager Community Manager
Message 1 of 15
keqingsong
Choo choo! The Fusion 360 update train has arrived! We brought you goodies around resiliency, modeling, sketching, as well as branch & merge, CAM, and much more. Head over to our What's New for more details:
http://www.autodesk.com/products/fusion-360/blog/january-19-2017-update-whats-new/
Bryce and Aaron also made a great video going over some highlights:
Note: We found an issue where sample data is missing. We figured out why this is happening and will be pushing a fix ASAP.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Replies (14)
Message 2 of 15
bronc3buster842001
The new move tools are awesome. Like that when you copy a component, it copies the sketches with it. Thats going to be helpful
Message 3 of 15
daniel_lyall
God I hope there is no fails with this, no warning.
It looks good
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 4 of 15
kshea9RNL8
What a spectacular update!
No body works harder to deliver then Autodesk!
Thanks to the Autodesk Fusion 360 team, Fusion 360 is now my go to CAD CAM.
Ken
Message 5 of 15
daniel_lyall
You forgot to mention this http://autodesk-fusion.partcommunity.com/3d-cad-models/  Looks very handy
You dudes have done some good stuff in this update.
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 15
bronc3buster842001
Looks like now when using the move tool, the snap points dont show up. The snaps points in the move tool are handy to have. Please bring them back. Make them an option like in the new inspect tool
Message 7 of 15
jakefowler
@bronc3buster842001
Glad to hear the new Move options will be helpful 🙂
Unfortunately snap points aren't yet in the new implementation of Point to Point, but we're looking into it now! If you're trying to align two points on two different bodies/components, the Align command might also be able to achieve this.
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Message 8 of 15
Beyondforce
Hi Fusion Team,
Thanks for a really great update. I have a little feedback in regards to the move command, more specifically, why it doesn't remember the parameters!?
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 9 of 15
jakefowler
@Beyondforce
Thanks for posting, and glad to here the update is generally working well!
Some clarification on the new Move behavior:
Free Move (the default move mode) still behaves in the same way as before (complete flexibility over moving/rotating/changing pivot, but not able to remember values).
In order to move in a way that values are remembered, you need to one of the other modes (Translate/Rotate/Point to Point/Point to Position). Each of these are individually more limited in what they can do, but they have the advantage of being able to remember the input values. So in your example, you would probably want to use Rotate, select the pivot edge as the axis, and specify the rotation value.
We're still investigating whether we might be able to provide a combined Translate + Rotate tool that also remembers values - if we're able to do that, it would most likely still be less flexible than the existing Free Move mode, so we would probably want to keep that around anyway.
Hope that clarifies. Let us know if you hit any other issues with new Move (or any updated features).
Thanks!
Jake
Jake Fowler
Fusion 360
Message 10 of 15
After the update all the project that autodesk shared with me is gone. example workshop, design sample, cam sample etc..
How can us get it back?
Message 11 of 15
keqingsong
Yes, I made a note of this in the first post:
"Note: We found an issue where sample data is missing. We figured out why this is happening and will be pushing a fix ASAP. "
Keqing Song
Message 12 of 15
Beyondforce
Hi @jakefowler, thanks for the quick reply.
What you suggested is exactly what I was looking for. When I saw the "Rotate" option, I didn't make the connection that it's just like the Draft command (But better).
I'll keep testing and will let you know, if I finde something.
Excellent job guys 🙂
Cheers / Ben.
Ben Korez
| YouTube
Message 13 of 15
bronc3buster842001
Ill try that and see how it works. I just got use to the way it was. Was simple
Message 14 of 15
Beyondforce
Hi again,
I noticed that you haven't fixed the Units inside the Texture Editor yet. There are still stuck on "in" and not correspondence with the file default Units!
Ben Korez
| YouTube
Message 15 of 15
mcramblet
Launched Fusion this morning and was excited to see an update being downloaded. All good and useful stuff! My favorite CAD program continues to get better and better. Kudos to the entire Fusion 360 team.
