I am trying to design a marble track and in doing so chose to try and sweep the same profile along a sketched path. The problem is that for some reason this results in the body being turned at weird angles that cannot seem to be undone or reverted back to the face's original position. Below is an image of what I am attempting to describe (The blue marks being the desired location) alongside my files.
Solved by jhackney1972. Go to Solution.
I could not make much sense of your model so I created one of my own to demonstrate what caused your sweep twist and how to correct it. The Screencast shows the processes. My model is attached if you are interested.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Thanks for the help. I managed to fix the twisting issue from your guide but now I'm getting this overlap at the intersections. Any suggestions?
If you get your path sketch corner radii to match your chute profile, the corners will take care of themselves. The attached model is not what you want, I know, but I only did it to show how the corners will adjust if the radii are correct for the profile. Get your track sketch in place with adequate radii and then create a Plane Along a Path at any point your desire. Put your profile on that plane. This is what I did to show you the smooth corners.
John Hackney
Retired
