Issues closing a shape
contactK3SGW
contactK3SGW
Hello, I've looked for the solution to my problem but my englsih may not be good enough to find it.
I have a shape made of splines but I can't close it, the inside remains white. If I draw a line anywhere on the shape  sometimes it closes the shape and the inside gets blue, sometimes it doesn't.
Can anyone tell me how to solve it?
Thank you,
Mathieu.
No line : not closed
Line here : closed
Line here : not closed
Line here : closed !
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
contactK3SGW
The issue is on "criniere" sketch.
Thanks for watching !
g-andresen
I checked the connections between the segments and came across a missing connection, which I then closed.
günther
contactK3SGW
I did the same without finding the missing connection...thank you so much!
How can you explain that the shape gets closed when I draw a line somewhere else?
g-andresen
This is a curiosity where I can only speculate that when the lines come into contact, there is an irritation of the contour with the result that the profile closes.
günther
contactK3SGW
Ok...
Once again thank you very much.
Have a nice day,
Mathieu.
