Issue with nTop Extension: Imported Implicit Body appears coarse and exports as a simple box
saizaki.tomoki.p4
saizaki.tomoki.p4
Community Visitor
Community Visitor
I have a question regarding the nTop Extension for Fusion.
I successfully imported an Implicit Body from nTop into Fusion but I am facing the following issues:
  1. Visual Quality: The geometry appears extremely coarse and degraded in the Fusion viewport. The fine details designed in nTop are lost and the shape looks broken.
  2. Export Failure: When I attempt to export this body using "File > Export" (as STEP or STL), the resulting file only contains a simple box shape (bounding box), not the actual geometry I designed.
Could you please advise on how to fix this resolution issue and correctly export the geometry?
Thank you.
  • nTop
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
lauri_barnhart
Hi @saizaki.tomoki.p4,
I wanted to check in and see if you saw @g-andresen's follow up request and you still needed assistance, or if you found a solution to your question already? Please share any available screenshots or screen recordings so the community can assist you further.
All the best,
Lauri | Community Manager
