Issue with hidden geometry still being selectable
jeremyah6364
Message 1 of 30
jeremyah6364
Ever since one of the more recent updates, I've noticed that hidden sketches and surfaces are still selectable. This get really annoying when working with a lot of sketches that are close together, or stacked on top of each other like in the screencast I posted. Is there a setting to turn this off of is this a new bug with the new update?
The hidden geometry is selectable no matter what you are doing in the design tab, not just when you are editing a sketch.
Replies (29)
Message 21 of 30
euclidmandd
I'm glad to hear the bug has been found, and turning off auto look at sketch has fixed the sketching problem for me as well so far.  I'd like to point out though that this behavior is not isolated to sketches.  Here I had everything hidden (nothing visible in the window) and I'm still able to select geometry.  Will the fix to the bug that was found also address this?  Or maybe there's a setting I'm missing.
Message 22 of 30
jeremyah6364
@jeff_strater  Any idea when the update with the fix for this will be released?
Message 23 of 30
oddjobmonkey
any update on when this will be fixed? It's very distracting trying to work with this issue.
Message 24 of 30
No it is not
I am having massive problems with hidden objects wanting to get selected all the time.
Why the hell is this still an issue?
From what I can tell it only show up if I hide a item by pressing "v" not if I hide it by pressing the eye so I assume it have something to do with ghost items lingering after you hide something and deselect it.
but if you hide it without having the object selected then no ghost object is created
Message 25 of 30
jeremyah6364
Doesn't seem to matter if I turn the visibility off on the browser or using the "v" shortcut, every once in a rare while it still pops up for me. seems to be random for the most part
Message 26 of 30
mmtomlin
I'm having the same issue, I'm trying to merge bodies and all my hidden bodies are selectable, I have several hundred bodies that are hidden and selectable in this model which is not ideal.
Message 27 of 30
jeff_strater
@mmtomlin - please record a video of what you are doing, and share the model here, then we can take a look at it.
Jeff Strater
Engineering Director
Message 28 of 30
mmtomlin
Hi, sorry for the late response to this.
I have found a way to easily reproduce the bug:
If you bool subtract (combine - cut in fusion) and use a hidden body as the cut tool AND you have "keep tools" turned on, this results in the cut tool still being selectable but hidden.
If you can't reproduce this let me know and I can record a video.
Matt
Message 29 of 30
jeff_strater
Brilliant!  Yes, that is easily reproducible.  I created bug FUS-134286 for this.  Thanks for helping to reproduce it!
Jeff Strater
Message 30 of 30
viperx85
So a year later and this is still a problem? is there a option in preferences for it now? or is it still unresolved?
