Issue with contours and text
Hi there
New to the forum. I'm use Fusion 360 for plasma cutting.
I'm have a problem once I have added text to my sketch. Once I go to the manufacture tab, select the contours and complete the 2D set up, the program does not recognize the text portion.
Any help would be appreciated.
G
g-andresen
either extrude the text (cut-option?) or convert the text into a path >  right-click > Explode.
günther
etfrench
That doesn't sound normal.  Directly machining text works for me.  Attach your file to the thread for further investigation: File/Export/Archive file *.f3d
ETFrench
