Isolate command very slow performance
summerson1990
summerson1990
Hi! Could anybody say if there may be any tricks on how to improve the performance when using the isolate command? Unfortunately, I can't share my project to give you a better representation of the scene. I've got some component in my scene linked (not derived). This component consists of other child components. I can't really say if it's a very large component for F360 to work with but simply isolating any part in my scene (even if this part is not a part of the linked component) takes about 7-10 minutes. This component has not been created by me, this was provided to me as .step file. But the overall performance of the scene is adequate. The problem only occurs when I try to isolate something in the project. What is interesting is if I try to isolate some part in the source linked file it works fast but when this linked component lies as linked in other project it makes isolating command so slow. My desktop specs are AMD RYZEN 9 5950X 16-Core, 128 GB RAM, 4x 1 TB m.2 SSD, RTX 3090 GPU. I was trying to decrease the F360 visual effects but that didn't any success, also tried to change "Display Detail Control" to fixed (low). Is there any command to calculate the number of components of my problematic component in order you could say if this is too many for F360 to work with or maybe some other solutions? Thanks.
jeff_strater
@summerson1990 - I know that you cannot share your design publicly, but would it be possible to share it privately with us at Autodesk?  Up until now, I have not been aware of such a performance concern with Isolate, so it would be good to have a test case for us to analyze.  You can send me a link to the design via PM, if this is something that you'd be willing to do.  Thanks!
Jeff Strater
Engineering Director
summerson1990
Thanks for the reply. No, unfortunately, I'm not allowed to share it with anybody( Maybe some log file could be generated and provided from my side while making the isolate command?
jeff_strater
OK, I understand.  No, unfortunately, log files are not going to help in this situation.  Without some Fusion design data to work with, there is not much we can do.  Sorry...
Jeff Strater
summerson1990
Ok, I understand. If I'll get something the same with some other project that I could share I'll notify you.
