Is there a way to toggle a set of features ?
dark-ages-of-malekithii
Hello there.
Context : I create 3D keyboard cases with various location for female socket (usb-c, micro, mini usb) at different location of my design. I also want to make variations for small printers splitted in half.
Considering I have 3 socket + 2 size variation of my case, I have to make 3 version of my model, play with the timeline to activate or not the split in two halfs. Everytime I have to make a change, I have to do it on the 3 models.
Question : Is there a way to enable or disable a set of feature, maybe with a selection set ?
I don't want to delete the features, but just temporary disable them.
Thank's
jeff_strater
you can use selection sets + suppress features to do this.  It is manual, but you can make it work.  I will create a screencast to illustrate.
Also, what you really need are "configurations", which are a way to create designs that are driven by a table of settings, each row of which define a different configuration.  This is something that we are working on, but is not yet available.
Jeff Strater
Engineering Director
jeff_strater
here is a simple example that illustrates the idea:
Jeff Strater
Woaaah let me try that !
That's perfect. Also the french is « Mask feature » that is for me a better wording for the feature because it help distinguish the difference with the the other suppress button 🙂
I have seen that the French translation have been improved
Thank you for that, way better !
