Is there a way to default to the previous dimension entry?
Noah_Katz
Noah_Katz
When doing a series of fillets, offsets, etc., all with the same value, I have to manually enter it every time.
Is there a way to make the entry box have the last used value instead of the default?
josef.kucera
Hi @Noah_Katz
have you tried to use last input value?
Josef
Josef Kucera
Fusion QA
Noah_Katz
Ah, didn't know about that.
I see that it works if I input a dim # too - cool!
Thanks again, Josef.
You're on a roll 🙂
I hope you can keep it up and attend to some other as yet unanswered questions I posted  earlier today.
Thanks!
josef.kucera
Yes, I forgot to mention that for parameters it works as well...
Glad to hear that it helped.
Josef
Josef Kucera
Fusion QA
