FUSION360. Sorry, I wasn't sure if this section was Fusion360 exclusive or all Autodesk products. First time posting.
I'm trying to sweep a relatively complex profile along a helical path.
In every other CAD package I've used, I've been able to create the helix with Radius, Pitch, Height etc. and then use the path however I want.
99% of the time I don't want a circular coil. Sometimes I don't even want to use the path to create a body, it's a placement mechanism.
Every time I try to use the coil body, I have to see a big ugly spring that gets in the way of my project. And I can't seem to select the path line if the coil is toggled invisible.
I assume I'm not the only one who has found this a little frustrating.
