Is there a way how to move components to Subassembly?
Ezekiel12
Message 1 of 12
Ezekiel12
I think im doing something really stupid.... So I got several components and I need to merge them in subassembly. But nothing that I tried worked. This has to be something really simple and I am probably totally blind. Any help please?
Thx
Matt
Replies (11)
Message 2 of 12
Beyondforce
Hi @Ezekiel12,
Here you go:
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 12
Ezekiel12
Thx Ben, I really was stupid 🙂 I did not point o the name of the subassembly when i wanted to drop it but below it... awkward...
Thx and have a nice day! 🙂
Message 4 of 12
Beyondforce
Believe it or not, but you are not the first one who made this mistake (me) 😉
Ben.
Ben Korez
| YouTube
Message 5 of 12
TimPaterson
I think this is the exact same question I have.  However, I get absolutely nothing from this or any other screencast I've tried to look at.  Is it possible to get a description of what's going on or a narrated video?
Message 6 of 12
Beyondforce
You just Drag and Drop a component onto the other 🙂
Ben Korez
| YouTube
Message 7 of 12
TimPaterson
That's exactly what I expected, but when I tried it (a couple of weeks ago) it didn't work. But I tried just now and it did work, so thanks for setting me straight.
Message 8 of 12
grayed
Sorry, I watched that video full screen and still have no idea what it shows.
Message 9 of 12
aleksei_ovsienko
I don't think it works for bottom up assemblies with external components. I've tried and I've tried - it just doesn't.
Message 10 of 12
King
Interesting, maybe this is my problem as well. There doesn't seem to be any documentation on this that I have found, how did you find this difference out?
Message 11 of 12
TheCADWhisperer
@King
Can you File>Export your *.f3d or *.f3z file to your local drive and then Attach it here to a Reply?
Someone here will demonstrate with your actual data.
Message 12 of 12
aleksei_ovsienko
Well you can see on the video example above he's working with internal components. I always work with external components, because this is the only way to achieve collaboration and models interchangeability for cross-project use. I keep complaining about it here in every other thread but I don't think Autodesk cares much. External components is the only professional way to handle data. One part number - one CAD model that's used cross-projects.
But for some reason Fusion is developed with primarily internal components in mind. I think historically that's what they started with and added external components support much later. As a result a whole gamut of features that are available for internal components - like the subject of this topic or geometry modifications in assembly context - are not available for external component assemblies. And nobody seems to be in a hurry to fix it even though these are key capabilities expected from any mature CAD.
