Is the MacMaster Carr insert available in the trial version?
burnandreturn
burnandreturn
I have been a big cheerleader for Fusion 360 on a couple of forums I frequent.  One fellow that is on the trial said the insert feature for MacMaster is not available.  Is that so in the trial period?    And if so is it possible to apply for a startup license before the trial has expired?
MMC insert disappears if you are in offline mode. I hope this helps.
charegb
The trial version of Fusion360 is the Ultimate tier and it is 100% the same as the commerical version. You should see the McMaster command under the insert drop down in the modeling environment.
You can indeed switch to start up before the trial expires, please follow the instructions here - http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-F11CE532-C60F-4410-9AAE-6250004D832E
Bankim
