Is that normal!?
Is that normal!?
Beyondforce
Advisor Advisor
Is that normal!?
Beyondforce
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
TrippyLighting
Yes, unfortunately!
etfrench
Arcs are only approximate when zooming in.  As @TrippyLighting says "Unfortunately".  If Fusion 360 exposed the length and end point XYZ properties of lines and arcs it would make it much easier to verify coincidence.  Currently the only way to tell if the line or arc is accurate is to use it until a failure occurs.
ETFrench
Beyondforce
That's not an Arch! The curved line is a Spline.
Ben Korez
| YouTube
etfrench
Perhaps I should have said any non-straight sketch itemSmiley Surprised  Circles and arcs display the same behaviour.
ETFrench
