Is it possible to obtain joint values and use them as values for a dimension?
30104277
30104277
Hello my name's Darcy and i have a question regarding joints.
I am wanting to use the value obtained from a slider joint as a dimension within a sketch.
Is it possible to obtain these joint values somewhere?
I can easily make user parameters change a joint value but that doesn't allow for the smooth changes compared to grabbing the particular object and sliding it and getting various values in between.
Any help on how to obtain the slider values would be appreciated if it can't be done then i'll settle for manual input if i have to.
Thanks for your time.
Darcy
TrippyLighting
No, this cannot be done.
