Invisible Faces on What Should Be a Solid Body
andyliszewski
andyliszewski
Could someone please have a look at the attached picture, showing some sort of problem with a model of mine. That is supposed to be a face on a solid body, but for some reason is not there. Is there something I have done incorrectly?
promm
Andyliszenwski,
I am unable to tell what is going on from the image.  Can you share the file with me?  You can email an exported .f3z file or you can add me to the project.
mike.prom@autodesk.com
Cheers,
Mike
T2005
I've recently encountered the same issue. Did you happen to find a solution to the problem?
Best regards,
T. Keiper
TheCADWhisperer
