Invisible Components in Render Mode
All,
I've been working on a very large file for a couple days (rendering on multiple occasions) and have run into a bit of a snag. I am able to see my components, sketches, bodies, etc on all views except the render mode now. If I hover my mouse where the objects would be showing, it highlights the edges of the objects but doesn't actually show the objects. If I click render it doesn't render anything, and the same goes for Cloud rendering, it's just a white picture. I've checked to make sure Object Visibility has all boxes checked and I haven't to my knowledge changed any important features recently. I've attempted to fix by changing to DX9 rendering engine and also cleared user cache data. Thanks in advance. Screenshots attached.
- Charles
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
Sorry to hear that! Just to check - what happens if you go into the Modify menu (within the Modeling environment, not render) and select Compute All? This will recalculate your timeline. Do any errors or warnings appear in the timeline or does it appear clean? Do you also mind sharing the file with me so I can test on my end as well.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
James,
Thanks for the response. I did a Compute All and no errors were given.
I have sent you the share link and password in private message.
- Charles
I resolved my issue. It appears that the ground plane was above the model. *facepalm*
Thank you! I did the same thing, so your post and screenshot helped me a ton.
