Intersections at sketch/drawing
Remy18
Remy18
Is there a possibility to assign dimensions at the intersection of sketch lines without using construction lines to specify this intersection point ? This is also useful at 2D Drawings if the nose radius of the turning tool has been drawn within the turning contour, so the internal dimension at the intersection point can be assigned.
TrippyLighting
Nope. I am pretty sure though this has been suggested more than once in the Idea Station. Most definitely for Drawings. Throw in your vote, or create a new idea if yoou cannot find it. It should get votes quickly.
Remy18
Ok thanks I voted this Idea, topic can be closed then Smiley Wink I already though it should be mentioned before, but couldn't found this specific point so fast.
scott.price
Hey @Remy18 and @TrippyLighting -  We're getting close to implementing the apparent intersection behavior in Drawings that is discussed in this post and I was hoping you could help us
out with a few details.
So the Associative Apparent Intersection snap, is coming - as a follow up to this we also wanted to make sure we got the intersecting extension lines right (shown in blue below)
Open questions:
Do you have a need for the intersection extension lines to display in some cases when there is not a dimension associated to them?
Could you give a brief description of how you'd like to see the extension lines would be added to the view?
If you have any additional thoughts on this please let us know!
Thanks a ton,
Scott
TrippyLighting
@scott.price If you have not done so, you should definitely create a new thread for that and maybe ask @brianrepp if he can make it a sticky post.
That should yield much better response than digging out this old thread 😉
brianrepp
Good suggestion @TrippyLighting
Remy18
Great to hear this feature will be implemented !
Thinking out loud about the intersection apparent with extensions lines:
  • I doubt if displayed extension lines without a dimension associated to them, would add much value. Which function would these add for dimensioning products ?
  • Are these extension lines giving the direction of which way the dimension can be added ? If not, would'ntt it be helpfull to add an point at the intersection of 2 lines to be able to create Dimensions at different angles. I did add a screenshot where D1 is displayed for a dimension in the X- direction and D2 at an angle toward the intersection point. This way the intersection point is more 'universal'
