Intersected lines do not appear to be in the right place
angrdnsr
angrdnsr
I have a surface model, and want to draw another sketch that intersects the first surface, and then use intersect to create a sketch on the second plane.
Having done this, it appears that the intersected lines do not join up and hence  I cannot use them to create a patch.  Is this a bug with Fusion360?
I would upload an image but I cannot get it to attach as my image.jpg is apparently not in the correct format of image/jpg?????
wmhazzard
You should be able to embed the photo with the camera icon, the attached photo is broken. Also attach an f3d file of your model.
TheCADWhisperer
File >Export and then Attach your *.f3d file here.
angrdnsr
I have managed to work around the problem.  I think the issue is a couple of things.
I wanted to sweep a profile, and made a guide line by creating a sketch and using intersection to create the guide line.  However I do not think the profile accurately followed the guide line, as far as I could see.  To get around this I extended the profiles edges.
This then meant that the swept profile intersected the face I was sweeping it along.  I then created another sketch at 90 deg to the sweep to create an end cap for this profile.  I then used intersection to get the profile of the sweep and the guide surface onto the sketch.  But the resulting profile was not joined, and nothing I could do seemed to get a closed profile to create a patch.  Even though the lines clearly formed a closed loop.
I managed to use a different method to create what I wanted, but on a lot of my drawings I'm still having trouble when either projecting sketches or intersecting profiles.  I can create a line, use this to say extrude a surface, but then if I create a sketch and use intersect, the resulting sketch lines come out as several profiles, which then cannot be used for say a loft feature.
It seems that this is a fairly common issue and something that seriously needs looking at.  My original query on this thread I think was caused due an error in the intersected lines were not recognised as being joined together.
davebYYPCU
No File, Picture or Screencast, means your description means very little to those that could help, easier to explain from your data..
TheCADWhisperer
Yes, this is a common issue with inexperienced users and why the experts here will always request the actual file for diagnosis rather relying on word descriptions.
