Installing Fusion 360
Message 1 of 23
Hey, I am trying to install Fusion 360 on multiple computers with multiple users; however, whenever I do install Fusion it is only available to the user that installed it and no other user on the computer. If I go to Control Panel > Programs > Programs and Features, it will show that AbExDbManger and Fusion have been installed if I am logged in as the user that installed, but not for any other user. The computers are Windows 7 64 bit. Thanks.
Replies (22)
Message 21 of 23
baribak
Hi artypan,
I presume you found what you needed.
If anything else comes up feel free to reach out here on the forums.
Kevin Baribault
Fusion 360 Quality Assurance
Message 22 of 23
I am a registered for Fusion360. Would like to be able to install to my laptop also
Message 23 of 23
baribak
If you're asking if you can install Fusion 360 on a 2nd computer, the answer is yes. Fusion 360 can be installed on as many computers as you need. The use of Fusion 360 is based on your account.
If you're trying to install it and experiencing an issue, can you tell us what you are seeing? Additionally, if you've attempted an installation and it failed, there should be a log file - autodesk.webdeploy.streamer.log - that we can use to see what might be causing the failure. This file can be found at:
  • Windows - c:\users\{username}\appdata\local\autodesk
  • OSX - /users/{username}/library/logs
Kevin Baribault
